iPad sound cutting out/ intermittent
This is a discussion on iPad sound cutting out/ intermittent within the iPad 1 Forum forums, part of the Apple iPad Discussions category; Hi guys I'm having a few problems with the sound on my iPad. I'm running the latest os. The sound in all apps and other ...
Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By Snowy3uk2
Thread: iPad sound cutting out/ intermittent
    130807
    Dec 2011
    Uk
    Hi guys
    The sound in all apps and other sound eg keyboard clicks stops working intermittently, and the volume slider when I double click the home screen disappears. The sound sometimes comes back for a few seconds then goes again randomly. NB. Sound works fine with headphones
    I've done a lot of reading in other post, and have tried the following:
    1. Messed about with the mute switch/screen lock switch on side of iPad as well as in the settings menu
    2. Complete system reset via settings
    3. Reset holding home and lock
    Nothing has worked.
    Anyone experienced this? Anyone got a solution?
    Many thanks in advance, it's driving me nuts!
    48665
    959 times
    Brisbane, Australia
    23,546
    Hi and welcome to the Forum!
    Regarding your issue have you closed all your apps completely in the multi task bar? Try this :
    Do the four finger swipe up to reveal your multi task bar along the bottom. It will show all the apps that you have opened at one time or another. Long press one of these apps until they start to jiggle and red minus signs will appear above them all. Press all the minus signs, this will close them, not delete them. It's a good idea to do this regularly just to keep them all running smoothly, I do mine every night. Check and see if it is operating now. If not do a restart
    Another thought also, when you are playing using your headphones it is a good idea to stop the app first before taking your headphones out. Let us know if this makes a difference
    Please read the Forum Rules
    iPad Air 128gb Wifi/Cellular - iPad 2 64gb Wifi/Cellular - iPad Mini 32gb Wifi/Cellular - iPhone 5 - Apple TV - MacBook Pro 15" - Time Capsule - Airport Express
    130807
    Dec 2011
    Uk
    Thank you for the help, I've tried what you've suggested but the sound still continues to cut out.
    Anyone else experienced this?
    165189
    Feb 2012
    My ipad is having the same problem. Same as described. I even tried restoring but sound still intermittent.
    96726
    Sep 2011
    8
    Same here. I think it's something to do with Bluetooth speaker interaction. Who knows? I close the app and make sure it's not running and the sound goes back to normal.
    207177
    May 2012
    Uk
    I have had the same problem with my ipad2. I tried a hard reset and on the advice of Apple i tried a full factory restore without then reinstalling any media or apps. When having done this I still found intermittent sound problems Apple agreed to replace my ipad as it was within its warranty period.
    I strongly suspect that this is a hardware issue and to do with the headphone port. I was able to get sound back by removing and
    replacing the headphones although the sound would fail again after a while. This may be as simple as having dust/dirt in the socket
    so if your ipad is not under warranty i would suggest trying a blast of compressed air in the socket.
    Lytrela likes this.
    275847
    Jan 2013
    Same problem here. I changed all my settings then resorted to a complete system reset but the problem recurred after a few days. I just discovered that closing the cover and plugging then unplugging my headphones fixes it (thanks for the input Snowy3uk2). This may be only temporary as well, but I'll take it over a reset. I'm far from any Genius bar.
    272012
    Jan 2013
    6
    Quote Originally Posted by Legbreaking View Post
    Hi guys
    Nothing has worked.
    Trie and restart it that might work or take it in to the shop
  1. Replies: 30
    Last Post: 08-18-2011, 03:37 PM
  2. Intermittent AirPrint Problem
    By RMSko in forum AirPrint
    Last Post: 06-12-2011, 09:16 AM
  3. ipad cutting off forum images
    By allanrube in forum iPad Help
    Last Post: 05-26-2011, 05:58 AM
  4. After 4.2 update, wifi intermittent
    By msimpsonnj in forum iPad OS
    Last Post: 12-26-2010, 09:04 AM
  5. Replies: 0
    Last Post: 11-19-2010, 08:11 PM
ipad audiobworks intermittently
ipad sound cuts out
ipad sound goes in and out
sound from ipad speakers going in and out
sound goes out on ipad 2
sound keeps cutting out on ipad
sound on ipad keeps cutting out
sound on my ipad fads in and out
Tags for this Thread
