I have a ipad 1 , its not hakced , i whas upgrading to the new os and after the restart my ipad stays in grey .. i have tryied so many things and still dont have a clue what did happen ,, it gives me a error 37 on itunes please help thankyou
This is a discussion on Ipad problem within the iPad 1 Forum forums, part of the Apple iPad Discussions category; I have a ipad 1 , its not hakced , i whas upgrading to the new os and after the restart my ipad stays in ...
Welcome to the forum, sorry it's under frustrating circumstances. Generally Error 37 is caused by an interruption in the upgrade process involving data corruption and more often than not it's caused by a virus protection program or firewall setting.
Having said that I would try one thing first, reset your iPad:
Reset the iPad: You can do this by pressing the Home button and the Sleep/wake switch on the top the iPad's case and holding them down together for at least 10 seconds, until you see the Apple logo. The iPad should then reset itself. The boot up process takes a few minutes and then the iPad should be responsive again.
If that doesn't work, and I suspect it won't, you'll probably have to restore your iPad to factory default. Here is how to do that:
Restoring your iOS device
Here are some tips about upgrading for anyone that follows:
iOS 5 Upgrade Troubleshooting
Hi and welcome to the Forum!
I'm sorry to hear about your problem and hope you straighten it out soon!
iPad 2 64gb 3G
it dosent seen to work , the ipad shows me after recovery error 37 and it turns a grey screen :/
Was that after doing the reset? U can always restore ur ipad but i hope u made ur back up before u got the error when the restore is done ur ipad should be back in the normal working stateOriginally Posted by krode
Hei..... My name fajri... I want to ask something to all of you the expert... How to download mp3 and video from ipad 2 wifii... Please help me master....
There's handful of free downloader that u can check out in the app store, i got idownloads plus and oplayerhd for my downloads needs!Originally Posted by fioyahud
