-1 error during my restore. HELP ! ! !
This is a discussion on -1 error during my restore. HELP ! ! ! within the iPad 1 Forum forums, part of the Apple iPad Discussions category; I am ready to put a bullet in my head at this point. Here's whats going on. First off I am more of a pc ...
Results 1 to 7 of 7
    278883
    Feb 2013
    CT
    First off I am more of a pc person vs an apple person so this might be part of the problem.
    My daughter was streaming video on my ipad 1 wifi and the battery died. Plugged it inand charged it to 100%.
    Upon the restart it wanted to activate the ipad using the wifi but failed a few times so I plugged it into itunes.
    It wanted to restore it, so I let it. Big mistake.
    At the very end of the restore it fails and presents a (-1) error.
    I brought it to the apple store and they cant/wont fix it (same error) and want me to buy a new one.
    I refuse because I now know its a software problem (firmware ?) and they want me to buy a new one.
    I keep trying to restore it with different cables/usb ports, no success.
    I fire up an old net book thst had an old version of itunes on it (version 6 ?) still no luck but now it gave another error code (3194). I tried searching for fixes utilizing DFU mode, latest apple firmware from your site, etc
    I tried following instruction that some folks on this forum recommeded such as looking at host files etc. no success.
    I get error 3194 everytime not matter what the itunes version except for the latest (11 ?) then I get the -1 error.
    Is this thing really dead ?
    HELP ! ! !
    13576
    1444 times
    Aug 2010
    Western NY state (USA)
    11,051
    Usually, a -1 error code indicates that there is a hardware fault with the iPad. I'm afraid that if you've tried to restore it AND so has the Apple Store, then it really is "dead."
    See this for further details on the -1 error code: iTunes: Specific update-and-restore error messages and advanced troubleshooting. Maybe it'll help you see if you can try to get it to work.
    P.S. I deleted your other post you made today on this same topic. Making more than one post not only fragments the conversation and makes it hard to follow - it's against the forum rules. Please keep any follow-ups, discussion or updates on this topic to this thread; do not start another. Thanks for your understanding.
    278883
    Feb 2013
    CT
    new twist ! ! !
    I got rid of the (-1) error and only the 3194 error exist (I think that is progress).
    Can I just bring it toi the apple store and let them give it another shot since the (-1) hardware error is gone ? Or will they just turn me away ?
    Thanks for your help !
    A
    13576
    1444 times
    Aug 2010
    11,051
    What iOS firmware version are you trying to install? Cause I just noticed that you are running and iPad1, right?
    An iPad can only go up to iOS 5.1.1.
    So, try running the install again - but use iOS 5.1.1.
    Worth a shot before going to the Apple Store again...
    Fid
    Fid is offline
    116331
    32 times
    Oct 2011
    Hinterlands of Northern California
    492
    Quote Originally Posted by steveofiveo View Post
    new twist ! ! !
    A
    Some of the time the errors are caused by your antivirus software. You can try to temporarily disable it before you restore your iPad. My antivirus software had choices to disable for a certain number of minutes or until next reboot. While the antivirus software is disabled you won't have protection from the outside so it wouldn't be wise to go anywhere else until you re-enable it.
    That upon which you dwell in the mind you become. - Lao Tsu
    iPad4 64GB, iPhone 4 - 32GB, iPhone 3GS 32GB (using as iPod)
    14571
    632 times
    Sep 2010
    Troon, Scotland
    7,104
    A 3194 isn't necessarily progress. It is actually a backwards step. It means you are not authorised to install the firmware you are trying to install on that device. Either you are trying an old file (which you cannot do, it must be 5.1.1), or you are not asking Apple for signatures because you have diverted to either Cydia or local (via TinyUmbrella).
    I suggest you follow all of the steps in our guide here - http://www.ipadforums.net/ipad-hacki...rsion-ios.html
    If you have shut down every other process on your PC that you can, and you still consistently get a -1, then it sounds like a hardware fault. To be honest, if the Apple Store gets a -1 error when trying to restore, then it sounds like a hardware issue to me. Despite what you may think, they do not deliberately fail to restore IOS on a device in order to force you to buy a new one.
    iPhone5 32GB 6.1.2 (evasi0n) | iPhone4S 64GB 5.1.1 (absinthe) | iPhone4 32GB 7.0b2 (stock) | iPhone3G 16GB 3.1.3 (jbme) | iPod Classic 6G 160GB (stock) | AppleTV 2G 5.0.2 (seas0npass)
    278883
    Feb 2013
    CT
    O.K. Here is the latest. I tried to update the Operating System via Redsnow. I believe I was able to get the firmware on it because it showed something "kernel" when it loaded. I tried the next step to load cydia but it would freeze. A little disappointing. I will try a couple more times and using the Operating System 5.1.1 as you folks recommended but I am unsure what version of Redsnow I should use (I appologize for my lack of computer skills but the apple is all new to me).
    Is there some thing else I should try ?
    Apple tried again and they came up with (-1) so as mentioned earlier, I might be dead in the water.
    I appreciate everyone's help.
    Thank you
    S
  1. Unable to restore error (-1)
    By rizzle in forum iPad 2 Forum
    Last Post: 02-08-2013, 04:07 PM
  2. How To Resolve Error 37 Restore iOS 5.0.1 on iPad 1
    By octavirawan in forum iPad Hacking
    Last Post: 06-22-2012, 05:57 PM
  3. Ipad 1 keeps getting restore error
    By iluvmyipad in forum iPad Help
    Last Post: 03-22-2012, 12:58 PM
  4. error when trying to restore! please help
    By blackhelio in forum iPad Help
    Last Post: 03-14-2012, 10:03 PM
  5. ReStore Error (-1) Help Me...
    By garpike in forum iPad Help
    Last Post: 02-08-2012, 07:24 AM
(-1) error apple
-1 error
error (1) during restore
