Results 1 to 10 of 13
Thread: charging issues
    267323
    Dec 2012
    indiana
    15
    charging issues
    so i got an ipad one given to me bc of water damage. Replaced the batteries with a new set restored and updated to 5.1.1 and it will not charge. It syncs and shows the trickle charge symbol but never charges past 1%. Ill include a pic but i have been searching high and low to no avail.charging issues-2013-01-02-09.01.22.jpg
    267323
    Dec 2012
    indiana
    15
    also my chargers are all 5v 1 amp or less.
    Moderator
    131244
    730 times
    Dec 2011
    Regina,Canada
    15,104
    Quote Originally Posted by partin_us_99
    A normal iPad charger is 10 watts. Have you tried charging your iPad with one of those?
    267323
    Dec 2012
    indiana
    15
    Re: charging issues
    I don't have a 10w charger. Figured my iPad 2's charger would work but even then my iPad original won't charge it says not charging while plugged into comp and 1% with the plug icon in the battery indicator.
    Sent from my SAMSUNG-SGH-I997 using Tapatalk
    Moderator
    131244
    730 times
    Dec 2011
    Regina,Canada
    15,104
    It's always possible that the battery has become defective, it may also be a problem with the connection between the battery and the charging socket.
    97693
    545 times
    Sep 2011
    Michigan. USA
    15,721
    Quote Originally Posted by partin_us_99 View Post
    so i got an ipad one given to me bc of water damage. Replaced the batteries with a new set restored and updated to 5.1.1 and it will not charge. It syncs and shows the trickle charge symbol but never charges past 1%. Ill include a pic but i have been searching high and low to no avail.Attachment 32793
    And since you started another thread, I am deleting the other thread since we do not want two similar threads open.
    267323
    Dec 2012
    indiana
    15
    ok skumonkey. scifan 57 the connection is good bc if there were not a somewhat decent connection it wouldnt run at all. Atleast the screen wouldnt power up. And it does it with the old and new battery so ik it's not the battery. Only culprit i can think of is the dock cable assembly the runs from the bottom to the logic board. Or not enough power from the charger. Trying to get a new charger to rule that out.
    267323
    Dec 2012
    indiana
    15
    to no avail ive tried resetting the connection on the battery to board tried every tip and trick to get this thing to charge looks like i've got a parts pad lmao
    Moderator
    235421
    151 times
    Aug 2012
    Adelaide, South Australia
    2,154
    As scifan pointed out above you need to charge your iPad with a 10w charger. The reason for that is that a computer (other than some iMacs) simply does not provide sufficient charge through a USB port, other than a very low trickle charge which would seemingly take forever if at all.
    You should not be using the USB connection cable to charge your iPad, but should be using the 10w charging cable connected to a home power point. You say you do not have that so you will need to buy, borrow or steal that vital gizmo.
    Regards,Andrew
    ​Please come back to say whether a member's assistance solved a problem. Others may be helped by that.
    Everybody please read the forum rules--->
    iPad3 64gig black, PC Windows 8 Pro, Samsung Galaxy mobile phone, Electrolux refrigerator (cool version)
    270600
    Jan 2013
    Hey first you can contact to Apple store.
  1. Replies: 1
    Last Post: 03-27-2012, 09:09 PM
  2. "Not Charging" and other issues
    By rstan2001 in forum iPad 1 Forum
    Last Post: 11-19-2011, 12:39 PM
  3. Charging issues
    By wyattdvm in forum iPad General Discussions
    Last Post: 10-17-2011, 02:01 PM
  4. Replies: 7
  5. charging issues
    By dmanero in forum iPad Help
    Last Post: 07-07-2010, 07:07 PM
battery indicator
ipad 4 charge symbol on but not charging
ipad charge symbol
ipad charging symbol
ipad not charging and the charger looks damaged
ipad2 logic charging issues
low battery en ipad
symbol of not charging ipad
