Roaming problems - India
This is a discussion on Roaming problems - India within the International iPad Users forums, part of the Regional iPad Groups category; I am using BSNL 3G sim. It works perfectly wherever I am in Tamilnadu 3G sometimes and Edge mostly. Works perfectly on 3G in Chennai. ...
Results 1 to 2 of 2
    8324
    Jun 2010
    Chennai, India
    27
    I have traveled to Mumbai twice and I am on Mumbai - Goa highway today. Connected to Dolphin and Cellone respectively. Though I can see the full strength signal bars, I am unable to access internet - error message says your connection not activated. Has someone found a workaround for this?
    I tried the same sim on my 2g phone, I am able to make voice calls!!!
    Hope someone can tell me what to do!
    Anyone else with seamless roaming in India may post their experience so that it can be useful for others.
    Thanks in advance
    PS: Neither 3G nor Edge indications were visible while roaming in Mumbai / Maharashtra
  2. #2
    krk
    krk is offline
    36406
    Mumbai
    5
    BSNL seamless roaming with following APN settings.
    APN: bsnlnet
    Login and password tobe left blank.
    Works while roaming in MTNL as well.
    This APN setting is auto updated via carrier setting updates while connected to the iTunes.
    These settings would not help if you do not have the 3G or edge indicator in the first place.
    The reason for no 3G indicator possibly due to the in progress deployment of 3G network, however edge should have been possible, not sure if you tried connecting manually at various times and locations.
Sponsors
  1. Will my ipad work in India?
    By richma in forum iPad General Discussions
    Last Post: 12-19-2010, 12:56 PM
  2. Avoid international roaming charge US model 3G
    By Roundplay in forum iPad Help
    Last Post: 12-07-2010, 03:08 PM
  3. Using UK iPad in Goa, India?
    By Colva in forum iPad General Discussions
    Last Post: 09-05-2010, 11:30 AM
  4. Hi from India
    By dilipc in forum New Member Introductions - Site Assistance
    Last Post: 07-29-2010, 12:42 PM
  5. Hello from Hyderabad, AP, India
    By HarryLarson in forum New Member Introductions - Site Assistance
    Last Post: 07-16-2010, 12:35 PM
3g sim roaming india
apn details for ipad 2 for roaming in india
bsni 3g roaming settings
bsnl 3g apn tamilnadu
bsnl apn settings for roaming on iphone
bsnl iphone international roaming
bsnl mumbai roaming apn
cellone 3g ipad roaming mumbai
connectivity issue in i pad while roaming.
dolfin 3g setting during roaming
gprs setting while roaming bsnl
i am tamilnadu bsnl user.when i come to chennai is it roaming for 3g
internatioal roaming to bsnl settings
ipad 2 tariff bsnl with roaming
iphone roaming india
manual settings for bsnl tamilnadu sim while roaming in mumbai
problems with wireless roaming
roamed sim not working on ipad no service
use mtnl 3g in roaming on bsnl cellone network
what are the gprs settings for bsnl tamilnadu prepaid while roaming in mumbai
