How to downgrade ipad 2 3g wifi ios 6 to ios 5.1.1 because wifi ios 6 do not working after upgrade from ios 5.1.1. Thanks
This is a discussion on my wifi trouble within the International iPad Users forums, part of the Regional iPad Groups category; How to downgrade ipad 2 3g wifi ios 6 to ios 5.1.1 because wifi ios 6 do not working after upgrade from ios 5.1.1. Thanks...
Unfortunately, there is no way to downgrade back to iOS 5.1.1 after upgrading to iOS 6. Sorry.
So, if you could detail what is happening with your WiFi and the iPad, maybe someone here can help....
My ipad wifi coverage lacking in the same room when I got the iphone wifi network
Have you tried to "forget" the WiFi network (via the Settings app) and then re-found/re-loaded that network onto your iPad? Have you reset the router (even though it works for the phone, a reset will not hurt and may help the iPad connect).
Or, have you tried a restart or a reset of the iPad to see if that'll work? To do (apologies if you know):
If that doesn't help, try this last step...
Reset: Hold both the power and home buttons until the screen goes dark and the Apple logo then appears (the slide to unlock screen may or may not appear). Once the logo appears, release the buttons. After a time, your homescreen will appear. Please note that it may take some time for the Apple logo to appear or for your homescreen to appear (or both). This is normal. Eventually, the homescreen will appear.
See if any of that helps. Holler back if it doesn't and we'll try something else.
