Ipad battery
This is a discussion on Ipad battery within the International iPad Users forums, part of the Regional iPad Groups category; Is it true that we should'nt run out the ipad battery or going below 5%? Or is it the opposite? Meaning, not to charge if ...
Results 1 to 10 of 11
Thread: Ipad battery
    212571
    Jun 2012
    Malaysia
    Ipad battery
    Is it true that we should'nt run out the ipad battery or going below 5%? Or is it the opposite? Meaning, not to charge if the percentage of battery is higher than five percent?
    85546
    575 times
    Aug 2011
    Edmonton AB Canada
    9,847
    It makes no difference when you charge your battery. Modern batteries do not develop a memory, so charge whenever you like.
    Apple recommend discharging completely once a month to recalibrate your battery meter but that's all.
    I keep mine topped up for the most part, but sometimes partially charge it if it is getting very low.
    Whatever you do, you won't do any damage.
    I've deleted your other thread asking the same question as we discourage multiple threads asking the same question.
    Sent from my iPad 4 HD mini
    Apple Equipment (so far) rMBP 15"; iPad 2 (iOS 7.1); iPhone 5s (iOS 7.1); iPhone 4 (iOs 7.1); AirPort Extreme; Airport Express; AppleTV
    212571
    Jun 2012
    Malaysia
    And is it ok if we use the ipad while it is charging?
    211965
    Jun 2012
    Canada
    31
    Yes. You shouldn't discharge them all the time. I did it once with my BB battery where I left it discharge every other day because I was too lazy to charge it. The battery was holding 15% of the charge after one month so don't discharge lithium ion battery.
    85546
    575 times
    Aug 2011
    Edmonton AB Canada
    9,847
    That reminds me. You should never leave any battery in a discharged state. If for some reason you don't use your iPad for several months, charge it up every now and then as it will discharge slowly over time.
    171353
    Mar 2012
    28
    Hi
    My iPad 2 battery has always lasted really well, but I just charge it every night on my nightstand anyway. I use it all the time, including reading before I sleep. I am pretty sure I usually did not get below 50%, but now I am doubting myself! I even listened to my music via bluetooth headphones for most of a 14 hour flight last month, and then, of course, the battery went down to almost empty.
    In the last couple of days, with just regular use, email, diary, tasks, the battery is draining much more quickly than usual, it's down to 18% from 100% this morning. I have switched off Bluetooth, closed all my apps, (I have used 9 today). Completely closed it down and restarted, but still high battery usage. I can't think what has changed to cause this. Does anyone have any suggestions?
    Thanks. Love this forum, by the way.
    211965
    Jun 2012
    Canada
    31
    Yea the iPad's battery life is actually incredible when it idles. It last weeks before I need to charge it.
    171353
    Mar 2012
    28
    I downloaded an App called Boost Magic last night. Followed supplied hints and tips, and instructions. Today, it is after 4pm, and my battery is showing 90%! Yay! It looks like this app really works. I would still like to know why my battery suddenly started depleting so much in the first place tho.
    213293
    Jun 2012
    18
    Quote Originally Posted by KevinJS View Post
    Unfortunately, noone suggest this to me before. When I got my new phone, kept iPad ideal for couple of months and few days before when i opened it, battery was not working at all ( even after charging), and part of it was swallowed from the middle. Can I make it functional again ?
    171353
    Mar 2012
    28
    Quote Originally Posted by henry98
    Sorry, not quite sure if you are talking about your iPad or iPhone. What was swallowed from middle?
  1. iPad 2 battery
    By Ejc1978 in forum iPad 2 Forum
    Last Post: 05-05-2012, 09:12 PM
  2. How often do u charge battery to save battery life
    By eddiethebhoy in forum iPad General Discussions
    Last Post: 04-24-2012, 04:29 PM
  3. The New iPad Battery
    By MelvynLoh in forum iPad 3 Forum
    Last Post: 03-17-2012, 10:23 AM
  4. iPad 2 Battery Tip
    By Duckfeet in forum iPad 2 Forum
    Last Post: 06-27-2011, 12:18 AM
i pad bettery runs out quickly all of a sudden
if a ipad 4 is charging should it run out of battery
ipad battery
ipad battery suddenly depleted
ipad is all of a sudden charging slow
ipad not charging below 5 percent
quickly discharge ipad
what causes my ipad to restart suddenly!
