Results 1 to 4 of 4
    60437
    May 2011
    norway
    help help and more help from Norway
    Hi There
    what a great forum, so much great info. I was wondering if anyone can help with some info. I am planning on buying a Ipad 2 when i come over to the US in July, but the question is.... if i can use it back here in Norway?
    I see that there is something called verizon? and another brand but what do i ask for if i dont want it with a subscription connected to a us network?
    I am going to either buy a 32 gb wifi 3G or a 64 gb 3G but they have to be able to be used here in Norway.
    Does anyone have any knowledge on what i should purchase and also what is the best of 32 and 64?
    So grateful for some help here
    Kind Regards
    shoppingdiva1
    116 times
    15,249
    Quote Originally Posted by shoppingdiva1 View Post
    Hi There
    Kind Regards
    shoppingdiva1
    There are two models of iPad available in the USA - AT&T and Verizon. AT&T is the version that will work in Norway - Verizon only works in the US and a few other countries.
    If you purchase an AT&T iPad in the US most Members recommend that you pre-authorise it in the US - i.e. you purchase a (minimum) pre-pay AT&T account, which will enable you to initialise the iPad 3G service in the US and check that it's working OK.
    But, please bear in mind that, although the prices in the US might look attractive, you'll have to pay VAT (Value Added Tax) and Import Duty when you return home and that makes the calculation far less interesting.
    60437
    May 2011
    norway
    Hi There
    Kind Regards
    shoppingdiva1
    ok thanks Tim for the info. are you sure it is the At/T that works over here, i heard the opposite. Do i then just buy a network for it over here? also what do you reccomend of a 32 or 64 gb? what is a good price for one of these now? sorry for all the questions but very knew to this ipad world :-)
    kind regards
    116 times
    15,249
    Hi There
    Kind Regards
    shoppingdiva1
    kind regards
    Absolutely - you have been misinformed - Verizon does not work in Norway. Verizon is CDMA, AT&T is GSM. There is no CDMA in Norway.
    Whether you purchase 32 GB or 64 GB entirely depends upon your expected usage. If you're into music and movies - 64 GB. If you're not, then 32 GB would be OK. A movie takes about 1 GB - OK - it depends on whether it's SD or HD and the length, but that gives you an idea...
    But, I repeat, check the Import Duties and VAT....
  1. norway 3g?
    By sjleworthy in forum iPad 2 Forum
    Last Post: 08-03-2011, 08:30 AM
  2. Hello from Norway
    By Racer2 in forum New Member Introductions - Site Assistance
    Last Post: 11-24-2010, 12:37 AM
  3. Hi from norway
    By Pincode in forum New Member Introductions - Site Assistance
    Last Post: 05-23-2010, 08:32 PM
  4. New From Norway
    By Janko25 in forum New Member Introductions - Site Assistance
    Last Post: 05-02-2010, 05:38 AM
  5. First Norway, now Korea
    By Seadog in forum iPad General Discussions
    Last Post: 04-26-2010, 10:38 PM
att ipad norway
buy ipad norway
can i use an ipad bought in usa in norway?
can i use iphone in norway
use ipad in norway
using ipad in norway
using iphone in norway
using my ipad in norway
verizon ipad i norge
will my ipad work in norway
will my iphone work in norway
will my verizon iphone work in norway
