AM trying to view Lovefilm movies on tv, via iPad. I have an iPad converter to VGA cable, and a VGA to HDMI cable. thought all I had to do was connect, but no joy at all. Any tips would be great .. Thanks
This is a discussion on Any help would be great within the Home Entertainment Systems forums, part of the iPAD Connect category; AM trying to view Lovefilm movies on tv, via iPad. I have an iPad converter to VGA cable, and a VGA to HDMI cable. thought ...
You would be better off with the iPad to HDMI adapter, and a HDMI cable. Or using the VGA adapter you already have and connecting it to the VGA input on your TV. Your TV may not support a VGA signal through its HDMI input.
try apple tv and start using airplay wirelessly no need to stand up to pause/stop the video sit on the couch and control your tv wirelesslyOriginally Posted by nearlynan
iPad 3
