Need help connecting my iPad to a Onkyo TX-8511 Receiver
This is a discussion on Need help connecting my iPad to a Onkyo TX-8511 Receiver within the Home Entertainment Systems forums, part of the iPAD Connect category; I have the proper cable but none of the portals are connecting. Also, which setting should it be on ie. cd,tuner,tape. Any help would be ...
Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By The OB
Thread: Need help connecting my iPad to a Onkyo TX-8511 Receiver
    306193
    Nov 2013
    Reno, nv
    Any help would be greatly appreciated.
    Sarah
    49720
    417 times
    SC
    6,342
    Exactly what are you trying to do? How do you plan to connect your iPad to the receiver and what do you want to happen? What cable do you have and how does it connect to your iPad?
    mini iPad w/ RD - 128 LTE - Space Grey | iPhone 4S - 64GB - White | Nexus 10 | Nexus 7 2013 | Kindle Fire
    * * * Forum Rules * * *
    iPad Ninja
    219668
    368 times
    Jun 2012
    California
    1,944
    Quote Originally Posted by Sarah woodburn View Post
    Sarah
    Because your receiver does not have Bluetooth capability you need a cable that has a 1/8" stereo jack that feeds two RCA jacks (one right channel and one left channel RCA jack). This cable will plug into your iPad's headphone connection with the 1/8" jack and into one of your receiver's input sections with the RCA jacks.
    If you do not have a CD hooked up to your receiver that will be the best choice, otherwise Tape-1 or Video-1. Remember, the input to the receiver may damage the input stage if turned up too much on the iPad (I do not know if your receiver has a limiting circuit on the input stages or if the iPad will automatically switch to line level out if it senses what it is hooked into) so have your iPad volume down to at least half until you can compare output levels with another source.
    Set the volume on the receiver to a comfortable level using a record, CD, VCR, DVD or radio. Now select the input you hooked the iPad to and play some music. Adjust your iPad's output level up or down until the sound is really close to the level with your reference source.
    85546
    579 times
    Aug 2011
    Edmonton AB Canada
    9,851
    The only input you should not use is Phono. This is a special input for use only with turntable, and has different characteristics to the others. As far as I can remember, its output is biased towards the treble, and will give strange results.
    Here is a link to a PDF for your receiver if you don't already have one.
    http://www.intl.onkyo.com/downloads/...1_manual_e.pdf
    Moderator
    235421
    616 times
    Aug 2012
    Adelaide, South Australia
    3,655
    Quote Originally Posted by KevinJS View Post
    Nice to see you back again mate!
    Andrew
    Sent from Oz using Tapatalk
    KevinJS likes this.
    Please come back to say whether a member's assistance solved a problem. Others may be helped by that.
    Check out the rules~ http://www.ipadforums.net/forum-rule...ease-read.html
    iPad3 64gig black, much unused PC Win 8.1 Pro, Samsung Galaxy mobile phone, Electrolux refrigerator (cool version)
  1. Connecting iPad3 to Stereo Receiver
    By SherylT in forum iPAD Connect
    Last Post: 10-01-2012, 05:32 PM
  2. iPad dock for Onkyo Receiver
    By Petergwy in forum New Member Introductions - Site Assistance
    Last Post: 12-06-2011, 11:51 PM
  3. GPS Receiver for wifi iPad
    By Gzoladz in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 09-20-2011, 05:09 PM
  4. Ipad 2 to analog av receiver
    By adracer in forum Apple TV
    Last Post: 09-18-2011, 12:28 PM
  5. Connecting with bluetooth Sony Receiver
    By rmcglohn in forum iPad General Discussions
    Last Post: 06-24-2010, 01:36 PM
can i hook my ipad to my onkyo
connect ipad to onkyo receiver manual
