How To Guide for Using VoiceOver in iOS 5.1
This is a discussion on How To Guide for Using VoiceOver in iOS 5.1 within the Help for iPAD Special Needs Users forums, part of the Special Needs iPad Forum category; This How To guide is designed for those who are visually impaired, or those who know someone who is. It will show how they can ...
Results 1 to 10 of 11
Like Tree6Likes
Thread: How To Guide for Using VoiceOver in iOS 5.1
    37823
    479 times
    Cranbrook, Kent, UK
    15,236
    This How To guide is designed for those who are visually impaired, or those who know someone who is. It will show how they can enable the specific functions that Apple provide as standard to aid them in their use of their iPad.
    VoiceOver provides a variety of functions to enable those who have limited or zero vision to be able to use their iPad. It will give descriptions of any area of the screen, speak as you type, allow you to choose options and functions and even connect to Braille devices. With the advent of iOS 5 everyone can enjoy using an iPad.
    VoiceOver will tell you which orientation that your iPad is in, it will also tell you if the rotation of the screen is locked. It will announce when you go to a new screen then read the first item on that screen (normally the item or app at the top left of the screen.
    You can navigate by tapping or dragging your fingers around the screen and VoiceOver will describe what is at the location where your fingers are.
    To be able to quickly turn VoiceOver on and off the triple click home button function can be enabled.......
    To enable theVoiceOver function we first have to open the the Settings App. By default the App will open on the General Tab. Then scroll down to the Accessibility tab on the right hand side.this will then open the menu containing VoiceOver.........
    You should now have the VoiceOver control panel open. So it's time to turn it on, but before you do you'll need to learn a few things which are different to normal. Firstly not all the normal gestures will work, secondly, we have some new functions which are.....
    Single Tap: a single tap anywhere on the screen will highlight that area and describe what is there, if it's text it will read the text and tell you if there is a function associated with it and how to operate it.
    Double Tap: this will select the item, for example it will turn a function in settings from off to on.
    Triple Tap: this will take you back to the home screen.
    So, now turn VoiceOver on. The first time you do this you should see this screen which just warns you that gestures settings will change.
    Your iPad should now be talking to you and describing anything that you touch on the screen. So let's look at a couple of the key settings, Speak Hints and the Speaking Rate controller for the iPads speech. (NOTE: you can mute/un-mute VoiceOver by double tapping the screen with three fingers.)
    When Speak Hints is turned on it will also tell you if a function is available and if it is then it will tell you how to activate it. This function defaults to on and unless you are an experienced user it is probably best to leave it on.
    The Speaking Rate controller does what it says, it allows you to speed up or slow down the speed the VoiceOver speaks at. To adjust the Speaking Rate, double tap and hold then drag to the left to slow down or drag to the right to speed up.
    Next we will look at Typing Feedback, by default this is set to both characters and words for both the software keyboard and hardware keyboards (it is not advisable to change these settings)......
    These settings are fairly self explanatory but should you be unsure, Nothing - no feedback when typing letters or for completed words; Characters - only feedbacks on typed letters; Words - only feedbacks on completed words; Characters and Words - feedbacks both individual letters and completed words.
    The next setting is Use Phonetics......
    This setting works when typing, when switched on, instead of just speaking the letter being typed it will also speak the Phonetic Alphabet, for example, if you type the letter e, it will say "e" followed by "echo".
    Now we will look at the Pitch Change function.......
    When enabled this has a couple of functions. When typing a higher pitch is used when entering a letter and a lower pitch is used when deleting a letter. Whilst reading, the first word is read at a higher pitch and the last word is spoken at a lower pitch.
    The Compact Voice function changes the reading voice. This setting is either off or on.......
    Next up is Braille. iOS 5.x.x has support for many external Bluetooth devices. For a complete list check out this link http://www.apple.com/accessibility/i...e-display.html
    The Braille settings can be found here.......
    The Rotor control is an amazing little secret of iOS VoiceOver. It is a virtual dial which can change the function and results of the up/down flick gestures (described further on in this guide). To use the Rotor control, place two fingers on the screen and rotate one finger around the other, the dial will appear and as you rotate different options will appear on the dial.......
    If you are typing then the Rotor can be used to change the language that you are typing in.......
    Speak Notifications does exactly what it says on the tin, it will tell you what the notifications are when you unlock your iPad. If this function is turned off then it will just speak the time when you unlock your iPad.
    In the next posts I will add the list of commands and options which are available in iOS for the VoiceOver function.
    This is really the tip of the iceberg for what can be achieved using the VoiceOver function. For indepth reading on this you can download the iPad User Guide For iOS 5.1 in the iBooks Store and search for VoiceOver. The guide is completely free and should be required reading for new users of iPads.
    Further information can also be found at Apple's website here http://www.apple.com/accessibility/ipad/vision.html
    NOTE: For those with limited vision it is worth noting that VoiceOver and Zoom functions cannot be used at the same time.
    TIP!: Up and down flicking (when enabled in Rotor) - The effect of the rotor depends on what you’re doing. When you read text in an email, you can use the rotor to switch between hearing text spoken word-by-word, character-by-character, or line-by-line when you flick up or down. When you browse a webpage, you can use the rotor setting to hear all the text (either word-by-word or character-by-character), or to jump from one element to another of a certain type, such as headers or links. (this paragraph is copied from the IPad User Guide For iOS 5.1 available for free in the iBooks store).
    TIP!: If you want to choose an item by name rather than search around the screen you can triple tap the screen with two finger which will bring up a search box and you can type in the item name.
    TIP!: So you want to hear your battery strength or wifi signal strength, it's almost too easy, tap the very top of the screen and your iPad will tell you!
    TIP!: So you want to revert to normal gestures whilst using VoiceOver, you can do that too! Double tap and hold the screen, the iPad will make a noise to inform you that normal gestures are in use, they will remain in use until you remove your finger.
    leelai and dinesh1212 like this.
    37823
    479 times
    Cranbrook, Kent, UK
    15,236
    Guide to VoiceOver Gestures: (taken from iPad User Guide For iOS 5.1)
    Navigate and read:
    Tap: Speak item.
    Flick right or left: Select the next or previous item.
    Flick up or down: Depends on the Rotor Control setting.
    Two-finger tap: Stop speaking the current item.
    Two-finger flick up: Read all from the top of the screen.
    Two-finger flick down: Read all from the current position.
    Two-finger "scrub": Move two fingers back and forth three times quickly (making a "z") to dismiss an alert or go back to the previous screen.
    Two-finger triple tap: Open the Item Chooser.
    Three-finger flick up or down: Scroll one page at a time.
    Three-finger flick right or left: Go to the next or previous page (such as the Home screen, Stocks, or Safari).
    Three-finger tap: Speak additional information, such as position within a list or whether text is selected.
    Four-finger tap at top of screen: Select the first item on the page.
    Four-finger tap at bottom of screen: Select the last item on the page.
    Activate:
    Double-tap: Activate the selected item.
    Triple-tap: Double-tap an item.
    Split-tap: An alternative to selecting an item and double-tapping is to touch an item with one finger, then tap the screen with another to activate an item.
    Touch an item with one finger, tap the screen with another finger ("split-tapping"): Activate the item.
    Double-tap and hold (1 second) + standard gesture: Use a standard gesture.
    The double-tap and hold gesture tells iPad to interpret the subsequent gesture as standard. For example, you can double-tap and hold, then without lifting your finger, drag your finger to slide a switch.
    Two-finger double-tap: Play or pause in Music, Videos, YouTube, Voice Memos, or Photos. Take a photo (Camera). Start or pause recording in Camera or Voice Memos. Start or stop the stopwatch.
    Two-finger double-tap and hold: Open the element labeler.
    Two-finger triple-tap: Open the Item Chooser.
    Three-finger double-tap: Mute or unmute VoiceOver.
    Three-finger triple-tap: Turn the screen curtain on or off.
    leelai likes this.
    37823
    479 times
    Cranbrook, Kent, UK
    15,236
    Rotor Options (taken from IPad User Guide for iOS 5.1)
    Reading text:
    Select and hear text by:
    Character, word, or line
    Speaking
    Adjust VoiceOver speaking by:
    Volume or rate:
    Use of typing echo, pitch change, or phonetics (using Apple Wireless Keyboard)
    See Controlling VoiceOver using an Apple Wireless Keyboard.
    Navigating:
    Heading
    Link, visited link, non-visited link, or in-page link
    Form control
    Table or row (when navigating a table)
    List
    Landmark
    Static text
    Items of the same type
    Buttons
    Text fields
    Search fields
    Containers (screen regions such as the dock)
    Zoom in or out
    Entering text:
    Move insertion point and hear text by:
    Select edit function
    Select language
    Using a control:
    Select and hear values by:
    Adjust the value of the control object
    leelai likes this.
    37823
    479 times
    Cranbrook, Kent, UK
    15,236
    Wireless Keyboard Commands for VoiceOver (Taken from iPad User Guide For iOS 5.1)
    VoiceOver keyboard commands
    VO = Control-Option
    Read all, starting from the current position
    VO-A
    Read from the top
    VO-B
    Move to the status bar
    VO-M
    Press the Home button
    VO-H
    VO-Right Arrow or VO-Left Arrow
    Tap an item
    VO-Space bar
    Double-tap with two fingers
    VO-"-"
    Choose the next or previous rotor item
    VO-Up Arrow or VO-Down Arrow
    Choose the next or previous speech rotor item
    VO-Command-Left Arrow or VO-Command-Right Arrow
    Adjust speech rotor item
    VO-Command-Up Arrow or VO-Command-Down Arrow
    VO-S
    VO-Shift-S
    Turn on VoiceOver help
    VO-K
    Return to the previous screen, or turn off VoiceOver help
    Escape
    Quick Nav
    Turn on Quick Nav to control VoiceOver using the arrow keys. Quick Nav is off by default.
    Turn Quick Nav on or off
    Left Arrow-Right Arrow
    Right Arrow or Left Arrow
    Select the next or previous item specified by the rotor setting
    Up Arrow or Down Arrow
    Select the first or last item
    Control-Up Arrow or Control-Down Arrow
    “Tap” an item
    Up Arrow-Down Arrow
    Scroll up, down, left, or right
    Option-Up Arrow, Option-Down Arrow, Option-Left Arrow, or Option-Right Arrow
    Change the rotor
    Up Arrow-Left Arrow or Up Arrow-Right Arrow
    Single-letter Quick Nav for the web
    When you view a web page with Quick Nav enabled, you can use the following keys on the keyboard to navigate the page quickly. Typing the key moves to the next item of the indicated type. Hold the Shift key as you type the letter to move to the previous item.
    H: Heading
    L: Link
    R: Text field
    B: Button
    C: Form control
    I: Image
    T: Table
    S: Static text
    W: ARIA landmark
    X: List
    M: Element of the same type
    1: Level 1 heading
    2: Level 2 heading
    3: Level 3 heading
    4: Level 4 heading
    5: Level 5 heading
    6: Level 6 heading
    leelai likes this.
    97693
    501 times
    Sep 2011
    Michigan. USA
    15,277
    Gabriel1--Many, Many thanks for posting this very informative Tutorial with the use of the Skitch App.
    This is extremely detailed with relevant links back to the Apple Website.
    The Voice Over Settings is just amazing for those with visual impairments or that need Text-to-Speech help due to verbal and nonverbal limitations. I have yet to try all the settings out-the rotary setting is one that is very interesting.
    Again Thank You-this will benefit many of our members here on how to use these wonderful settings!
    Skimonkey
    Gabriel1 likes this.
    48665
    479 times
    Brisbane, Australia
    19,173
    Gab,
    What can I say here, this is brilliant and will help so many.
    Well Done!!
    iPad 2 64gb 3G
    37823
    479 times
    Cranbrook, Kent, UK
    15,236
    Why thank you ladies.
    212393
    Jun 2012
    USA
    27
    With VoiceOver on, when I double-tap the screen wit two fingers at any time and in any app, whatever item I was last playing in the Music app starts up. I double tap and it turns it off. Is this a feature of VoiceOver or is there something wrong?
    252722
    Oct 2012
    Milan
    11
    THANK you soo much, skimonkey and gabriel1! I am buying an iPad for my mother, who at 72 has just been diagnosed with macular degeneration after suddenly losing the vision in her right eye. She has always been very active and independent and now is having a very difficult time, both logistically and emotionally, with EVERYTHING, and I am sure that the iPad's voice capacities will aid her immensely. And your posts will aid ME immensely in setting up her iPad so that she can use it!! Thank you, once again. This forum is truly a godsend!!
    Karina
    iPad 64GB WiFi/3G 1st gen & white 16GB iPhone 4 (iOS 5.1.1)
    37823
    479 times
    Cranbrook, Kent, UK
    15,236
    Quote Originally Posted by KarinainMilan
    Thank you, that is so good to hear.
    I'll check out the differences between iOS 5 and iOS 6 and update if required.
  1. iPad: Configuring accessibility features (including VoiceOver and Zoom)
    By col.bris in forum Help for iPAD Special Needs Users
    Last Post: 04-10-2012, 02:38 AM
  2. BB codes guide
    By IFile in forum iPad General Discussions
    Last Post: 01-17-2012, 04:01 PM
  3. Looking for pdf reader app with VoiceOver
    By zara26 in forum Productivity Apps Forum
    Last Post: 11-08-2011, 08:09 AM
  4. iPad2 VoiceOver
    By jknotts66 in forum iPad 2 Forum
    Last Post: 05-05-2011, 02:28 PM
  5. Guide to 4.2.1
    By mslammers in forum iPad General Discussions
    Last Post: 11-23-2010, 06:00 PM
how to read text on ipad using voice over
how to turn i-pad voice aid off
how to unlock ipad with voiceover
ios speaking speed control
ipad turn off voice assist
ipad voice over willl not turn on
ipad voiceover tips
voice over compact voice
voice over ipad read whole page
voice over wont turn on
voiceover and speak and notifications
voiceover keyboard commands ipad
