Why my iphone 5 and ipad does not sync all photos via icloud?
This is a discussion on Why my iphone 5 and ipad does not sync all photos via icloud? within the Forum Rules, Help and Info forums, part of the New Member Introductions - Site Assistance category; Hello! Im a new member here. I was trying to sync all my photos from ipad to iphone, but am having trouble. Selected pictures were ...
Results 1 to 8 of 8
    267297
    Dec 2012
    Hello! Im a new member here. I was trying to sync all my photos from ipad to iphone, but am having trouble. Selected pictures were retrieved from the ipad.
    579 times
    Dayton, WA
    13,188
    Photo Stream does not sync photos. It makes photos that are taken on one device available on your other devices. The difference is that photos that get to your iPad or iPhone by methods other than being taken and saved on the camera roll will not get copied to Photo Stream.
    iCloud: Photo Stream FAQ
    49720
    277 times
    SC
    5,365
    Not sure if I understand what you are saying. For example, I got a photo emailed to me. I saved it on my mini. I now see it in my photo stream on my iPad 3. It seems as if you are saying that shouldn't happen?!?
    579 times
    Dayton, WA
    13,188
    Poorly worded. Sorry.
    Anything that you save to the camera roll will go to Photo Stream. Albums synced through iTunes will not. Photos saved to the camera roll before you turn on Photo Stream will not. I'm not sure what will happen with photos imported via a camera connection kit.
    Syncing tries to keep everything the same in two or more places. Photo Stream, by contrast, only makes new stuff available in more than one place.
    It's a subtle difference, but it makes a profound difference in how it behaves, and what it's useful for.
    If someone wants to have access to recently taken/saved photos on all their devices, it works well.
    If someone wants the same set of photos on all their devices, Photo Stream is a poor choice. A third part solution (or syncing throuhg iTunes) will work better.
    49720
    277 times
    SC
    5,365
    It's a subtle difference, but it makes a profound difference in how it is used.
    Ah....I see now what you are saying. Yes, using photo stream is NOT the same as a sync.
    But photostream can be maddening. I've let mine get out of control. I guess I need to turn it off and do some major house cleaning. If you leave it on, it seems impossible to rid yourself of any photo.
    579 times
    Dayton, WA
    13,188
    If you've left it on for a long while, yes there can be quite a few, especially if you do a lot of screen shots like I do.
    I make it a habit to clean up my PhotoStream every so often, so it does not become a major chore, or require me to turn it off all together. I'd rather not let it max out. I have better use for my devices' storage space.
    For a clean sweep, you can clear it via icloud.com. Click on your name at the top right and choose Advanced from the settings dialog. You can reset the Photo Stream. That won't delete them from the device, but it will prevent them from coming back after you turn Photo Stream back on, on the device.
    267424
    Dec 2012
    I'm new to forum- how do I post a question?
    I wanted to see if anyone has any ideas on changing the keyboard in ipad 2 where it always is showing the new keyboard in all apps.
    Thanks!
    KookyKathy
    579 times
    Dayton, WA
    13,188
    Here's a thread on how to post.
    Creating Posts and Starting New Threads - How To
    As for your question, there is no way to change the default keyboard on the iPad unless you jailbreak, and I'm not sure what tweaks are available even then. You can read about jailbreaking in the Hacking forum.
  1. New on 8.14.12 from Oklahoma with need for Photos from PC to iPad / iCloud HELP!!!
    By LolaK in forum New Member Introductions - Site Assistance
    Last Post: 08-15-2012, 07:41 AM
  2. Sync notes on iphone 4 and mac book pro and ipad 3. i ihave a time machine and iCloud
    By Ian Denny Anderson in forum UK iPad General Discussions
    Last Post: 07-16-2012, 04:15 AM
  3. iCloud sync for iPad and iPhone
    By azonie in forum iPad 3 Forum
    Last Post: 03-21-2012, 09:26 AM
  4. icloud calendar sync to iphone
    By alibruty in forum New Member Introductions - Site Assistance
    Last Post: 10-28-2011, 09:12 PM
  5. Replies: 3
    Last Post: 10-22-2011, 04:43 PM
icloud not syncing photos
icloud photos not syncing
my iphone and ipad are not syncing
photo stream not syncing
photos not syncing to icloud
photos not syncing to ipad
photos not syncing to iphone 5
photos on iphone not on ipad
photostream not syncing
photostream not syncing all photos
photostream not syncing between iphone and ipad
why wont my iphone photos sync to ipad
