wi fi
This is a discussion on wi fi within the Forum Rules, Help and Info forums, part of the New Member Introductions - Site Assistance category; Only new to the ipad ,I would like to know what I need to do to be able to download more than the 50mb or ...
Results 1 to 2 of 2
Thread: wi fi
    262958
    Dec 2012
    wi fi
    Only new to the ipad ,I would like to know what I need to do to be able to download more than the 50mb or more,window pops up with wi if not connected.have tried various combinations in settings ,and followed advice from a family member. Using THE NEW IPAD with retina display and wifi. And Telstra 3 G ,prepaid. Can you advise what setting need to be at to enable downloads
    Fid
    Fid is offline
    116331
    19 times
    Oct 2011
    Hinterlands of Northern California
    409
    Hi Marie,
    Is your iPad wifi only? If it is one that can be used on a cellular network plan then you will get that message. The message will say that you have to connect to wifi to download apps that are larger than 50 mb if you are connected on the cellular network.
    Let us know what kind of iPad you have to help you figure this out. :-)
    If you only have a wifi only iPad and are using a portable hotspot I don't know why the portable hotspot would have a limitation. Is there nearby wireless hotspot that you can test out your iPad? Some place like a library or fast food restaurant?
    If your iPad has both wifi and cellular (3G/4G) you should be able to turn off the cellular data connection when you are using your wifi so the wifi will take precedence and you should not experience the 50gb limitation.
    Oh, a way to tell if you have a wifi connection is if you see an icon on the top left hand side that has a dot and two arcs above it when you are connected to a wifi signal. You may only see one arc above the dot if you are not receiving a good enough signal.
    That upon which you dwell in the mind you become. - Lao Tsu
    iPad1 32GB, iPhone 4 - 32GB, iPod Shuffle
    1GB
ipad cellular wifi precedence
what takes precedence ipad wifi or cellular
which takes precedence wifi or 4g on ipad
