Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By Nakedbabytoes
Thread: Closing apps
    248441
    Oct 2012
    Closing apps
    Hi I got the iPad after years of having iPod touch and I using my apps and in the middle of using it it closes my app for no reason, can someone please help?
    39523
    16 times
    Lincoln
    182
    Is there a certain app that is crashing most often? If you go into "Settings----general---diagnostics & usage----" what does it tell you the reason for the crashing is? Mine most often is safari, specifically when viewing Facebook. My iPad says the crashing is due to low memory, I assume I run out of RAM processing visual and HTML content if I have left any apps open in the system tray(double click home button and see all your open apps, hit the minus signs to close them). This will help if the issue is memory. Or you might have a bad app, in which case, delete the problem app and try reinstalling it.
    goofy8275 likes this.
    248441
    Oct 2012
    Thanks I'll try that!
    247844
    Sep 2012
    UK
    132
    Quote Originally Posted by Nakedbabytoes View Post
    How do I bring up the minus signs on the apps to close them?
    226933
    Jul 2012
    Inglis, Florida
    15
    Double click the home button
    39523
    16 times
    Lincoln
    182
    In the tray? They should come up when you double click the home button, then hold your finger on an app until they woggle and the minus signs come up. To delete apps by making them wiggle on your screens with minus signs, hold your finger on an app until they start wiggling, tap the minus sign, and it will ask you if you wat to delete...press okay/yes. Then reinstall.
    Some apps won't let you delete them, like the ones Apple puts in as native apps in the OS(like safari or FaceTime). So even though they wiggle, you won't get the minus signs on the big screen. But in the tray, the minus sign means close app, not delete app.
    248441
    Oct 2012
    Where is the home key located?
    39523
    16 times
    Lincoln
    182
    The round button at the bottom of your iPad on the front, it has a square on it.
    48665
    508 times
    Brisbane, Australia
    19,666
    Hi and welcome to the Forum!
    You can also place 4 fingers on your iPad and slide up and your multi task bar will be revealed also.
    iOS5 Tips and Tricks
    Easy pictorial shortcuts & Helpful places. - For People new to the iPad.
    iPad 2 64gb 3G
  1. Apps closing down a lot
    By awhmfc in forum iPad 1 Forum
    Last Post: 09-10-2012, 07:03 PM
  2. Closing all apps
    By rugger in forum iPad Help
    Last Post: 06-02-2012, 03:05 PM
  3. Closing apps
    By hberninger in forum iPad General Discussions
    Last Post: 05-30-2012, 12:43 PM
  4. Apps not closing..!!
    By Mayank Bhatia in forum iPad General Discussions
    Last Post: 04-10-2012, 02:37 AM
  5. Closing apps
    By tfmoore in forum New Member Introductions - Site Assistance
    Last Post: 01-06-2012, 05:19 PM
amost of my apps are closing
apps in taskbar won't close ipad
discussions closing apps
double clicking home won't show system tray on iphone
ipad apps closing
my ipad app close after jailbreak
