Weather network app no longer working
This is a discussion on Weather network app no longer working within the Forum Rules, Help and Info forums, part of the New Member Introductions - Site Assistance category; I have uninstalled, installed and rebooted several times. This is on ipad2...
Results 1 to 10 of 13
    223704
    Jul 2012
    Niagara Canada
    97693
    498 times
    Sep 2011
    Michigan. USA
    15,239
    Hi there--welcome!
    Not sure if you have done some of the other immediate fixes...but give this a try for when an app begins to act up.
    Force the app to quit by pushing the home button twice to bring up your multi-task bar. This will show all the apps that you have visited. By long pressing the app in question, it will begin to jiggle-press the red circle with the negative sign on the app. It will only quit the app and not delete. Than try to re-open the app and test out.
    Third is to do a soft reset by holding the power switch and home button together until you see the apple logo. Hope that helps!
    223704
    Jul 2012
    Niagara Canada
    Thank you I have tried all of those suggestions but with no success.
    97693
    498 times
    Sep 2011
    Michigan. USA
    15,239
    Have you done all of your updates to both the app and your iPad?
    223704
    Jul 2012
    Niagara Canada
    Yes, everything is up-to-date.
    97693
    498 times
    Sep 2011
    Michigan. USA
    15,239
    Well that's strange. You have deleted/reinstalled the app, force closed the app, restarted and also reset your iPad with no help.
    Have you contacted the developers? What do mean its not working? How so?
    223729
    Jul 2012
    I started having same problem yesterday with the WeatherEye Hd app crashing (after it worked fine earlier in the day) and husbands IPad (also a 2) started having the same crashing problem when you try and open - have tried all suggested fixes but no luck - have sent a note to support reporting it and hoping they come out with an update fix very soon!
    97693
    498 times
    Sep 2011
    Michigan. USA
    15,239
    Quote Originally Posted by Sewbear View Post
    That is great to hear. Let is know what comes of it, alright, Sewbear!
    223704
    Jul 2012
    Niagara Canada
    It starts to load but then crashes. I have been using it daily for 6 months without any prior problems. It is WeatherEyeHD. I haven't tried contacting the developers I shall try that.
    97693
    498 times
    Sep 2011
    Michigan. USA
    15,239
    Yes, that would be the best move there. Like what Sewbear has said, they made be due for a major update with constant crashing.
  1. weather plugin for lockinfo not working on ipad3
    By andyisavinit in forum iPad Hacking
    Last Post: 06-05-2012, 12:51 AM
  2. Replies: 4
    Last Post: 05-22-2011, 08:07 PM
  3. Photo sort no longer working
    By PCUK in forum iPad OS
    Last Post: 11-24-2010, 10:16 AM
  4. Reset iPad, no longer working.
    By Karl in forum iPad Help
    Last Post: 06-22-2010, 03:25 PM
iphone weather app not working
iphone weather not working
the weather channel app not working
weather app for ipad not working
weather channel app for ipad not working
weather channel app stopped working
weather channel iphone app not working
why does the weather channel app not working
why is my weather channel app not working
why is the weather channel app not working
