How do I unsubscribe from iPad Forums? Maybe the answer should be sticky.
This is a discussion on How do I unsubscribe within the Forum Rules, Help and Info forums, part of the New Member Introductions - Site Assistance category; How do I unsubscribe from iPad Forums? Maybe the answer should be sticky....
Hi jrs...you could go to your settings and locate the thread there. Next to the thread is "unsubscribed" in purple.
You can also Open up the subscribed thread and and see the black control bar above. Go to thread tools. It will pull down and give you the option to unsubscribe.
Hope that helps.
Or if you use the IPF App, go to the subscribed tab and swipe left to right on any threads you want to unsubscribe from and it will bring up an unsubscribe button.
