Hi, my screen keeps blacking out or crashing on numerous occasions, e.g. Whilst playing a game, or conducting a search on the internet, etc. My iPad is 2 months old; I have c. 8 gigs out of 32 left - help!
This is a discussion on iPad screen keeps blacking out within the Forum Rules, Help and Info forums, part of the New Member Introductions - Site Assistance category; Hi, my screen keeps blacking out or crashing on numerous occasions, e.g. Whilst playing a game, or conducting a search on the internet, etc. My ...
Hi and welcome to the Forum!
With regards to your question when an app behaves strangely it is best to close it completely and then relaunch it. From the home screen do the four finger swipe up or double press the home button to reveal your multi task bar along the bottom. It will show all the apps that you have opened at one time or another. Long press the app until it jiggles and a red minus sign will appear above it. Press the minus sign, this will close the app, not delete it. It's also a good idea to close all these apps, as it helps the iPad run smoothly, I do mine every night. Check and see if it is operating now, if not a restart is in order.
When an App or your iPad begin to behave strangely these are the first steps you should do to rectify it. Let us know how you go, good luck!!
iPad 2 64gb 3G
Thanks - your tips have helped me to solve the problem.
