Can someone tell me how to fix this problem?
Hi and welcome to the Forum
With regards to your question when your iPad begins to behave strangely it is best to close all your apps and do a restart and/or reset. To do this do the four finger swipe up or double press the home button to reveal your multi task bar along the bottom. It will show all the apps that you have opened at one time or another. Long press the app until it jiggles and a red minus sign will appear above it. Press the minus sign, this will close the app, not delete it. It's also a good idea to close all these apps, as it helps the iPad run smoothly, I do mine every night. Check and see if it is operating now, if not a restart is in order.
When an App or your iPad begin to behave strangely these are the first steps you should do to rectify it. Let us know how you go, good luck!!
iPad 2 64gb 3G
In addition to a misbehaving Safari (in which case leelai's advice is spot on), it sometimes may depend on what's happening at the web site.
I've noticed that I don't get the keyboard unless I've pressed on the space that requires keyboard input. Then (or if) I move away from the input blocks, my keyboard disappears.
If it's not this, or if leelai's advice doesn't work, please come back and tell us what web sites you are having issues with. Then, maybe we can test it ourselves to see if it's you, us or the web site.
Good luck.
