Error connection when trying to open 4od on my ipad2
This is a discussion on Error connection when trying to open 4od on my ipad2 within the Forum Rules, Help and Info forums, part of the New Member Introductions - Site Assistance category; Hi just got my ipad2 and i seem to have a problem with the 4od app. When first installed it was fine, next day when ...
Results 1 to 5 of 5
    144463
    Dec 2011
    Hi just got my ipad2 and i seem to have a problem with the 4od app. When first installed it was fine, next day when i tried to open it comes up with 'connection error' i,ve registered fine and not messed around with any setting, and also my wifi is good. Is anyone else having the same issue and does anyoune know a solution, i have already reinstalled it twice?
  2. #2
    48665
    156 times
    Brisbane, Australia
    9,430
    Hi and welcome to the Forum!
    With regards to your question when an app behaves strangely it is best to close it completely and then relaunch it. From the home screen do the four finger swipe up or double press the home button to reveal your multi task bar along the bottom. It will show all the apps that you have opened at one time or another. Long press the app until it jiggles and a red minus sign will appear above it. Press the minus sign, this will close the app, not delete it. It's also a good idea to close all these apps, as it helps the iPad run smoothly, I do mine every night. Check and see if it is operating now, and let us know.
    TIPS AND TRICKS - for those of us who don't know!
    iOS5 Tips and Tricks
    iPad 2 64gb 3G
  3. #3
    144301
    Dec 2011
    Quote Originally Posted by leelai View Post
    Just started using my new iPad yesterday and all day I was switching apps by going "home" and hitting app icon each time. I kept thinking there should be a way to more quickly switch! Thank you so much! Does this work with the iPhone as well?
  4. #4
    48665
    156 times
    Brisbane, Australia
    9,430
    Quote Originally Posted by MsTeach
    Yes it does work on the iPhone by double pressing the home button. Are you on IOS5 have a look Settings - General - About and look for version. With IOS5 came many new features, you can also switch between apps by swiping 4 fingers across the page and it will take you to your last used app and you can just keep swiping through them all. Here's 2 threads with lots of tips and shortcuts
    Let us know what version you're on and if you're not on IOS5 we can show you how to upgrade if you would like, it's also free just in case you're wondering.
    iPad 2 64gb 3G
  5. #5
    144463
    Dec 2011
    Hi leelai
    Thank you for your reply it sorted it out. Learning as I go.
    Happy new year
    Shippcat
Sponsors
  1. Replies: 0
    Last Post: 12-12-2011, 08:34 AM
  2. iPad 1 (v. 4.3.3) 3G connection ERROR
    By Amadeus45 in forum iPad General Discussions
    Last Post: 10-20-2011, 09:20 PM
  3. Open vpn for ipad2?
    By my_ipad_2011 in forum iPad 2 Forum
    Last Post: 07-28-2011, 11:47 PM
  4. hbo go internet connection required error.
    By stingray1059 in forum iPad Help
    Last Post: 06-27-2011, 05:26 PM
  5. camera connection kit-get error message
    By jthrall in forum iPad Help
    Last Post: 06-04-2011, 05:38 PM
4od
4od app
4od app australia
4od app united states
4od app usa
4od australia
4od error
4od in usa
4od ipad
4od ipad app in australia
4od ipad australia
4od on ipad
app for ipad 2 to work with ps3
get 4od app australia
hbo go ssl
hbo go ssl error
my info apple ssl error
myinfo.apple.com ssl error
ssl error hbogo
why does my ipad2 show connection errors
