how do I get rid of all the old web pages I have opened?
This is a discussion on Clear history within the Forum Rules, Help and Info forums, part of the New Member Introductions - Site Assistance category; how do I get rid of all the old web pages I have opened?...
Settings > SafariOriginally Posted by elaine.tamkin
Sent from my White iPad 4.
Hi and welcome to the Forum!
iPad 2 64gb 3G
Hi Leelai
Just downloaded app and joined forum because I need help....
I have a much loved iPad 2 (iOS 5.0.1) on which all of a sudden the video does not function properly. I have previously purchased several seasons of my favourite TV shows on iTunes and all has been well.
Two days ago I purchased season three of a series and now every time I open an episode, it plays for 30 seconds then closes. I also tried playing any other old downloaded show from many months ago which I have watched and the same thing happens. Also the series icons are not displayed correctly in the library.
So far, I have tried turning off and on and closing all other applications.
Any ideas anyone? Or do I need to go to the Apple store (sigh) and ask for help? Imagine the post Christmas rush....
thanks heaps for any help and ideas.
Krissie
A reset might work here, have a go and let us know how it goes.
Reset: Hold the power off button and the home button simultaneously, keep holding them in and you will see the power off slide appear and disappear, wait until you see the Apple logo appear before releasing the buttons. It will take a little longer for your iPad to start.
iPad 2 64gb 3G
Hi Leelai
Thanks for quick reply. Tried reset but did not work.
It seems every single episode I have ever purchased and downloaded plays for 30 seconds then closes... Mad Men included....
Sniffle :-(
I did a search and came up with this, I hope the answer is there for you, it sure fixed a few though. Try this and let us know!
IPAD Video not working
iPad 2 64gb 3G
