Does anyone know why I keep getting kicked off the Internet?
This is a discussion on Ipad within the Forum Rules, Help and Info forums, part of the New Member Introductions - Site Assistance category; Does anyone know why I keep getting kicked off the Internet?...
Hi and welcome to the Forum!
Can you give us a bit more info on your problem, are you on Safari when it happens, does it just go to the home screen? Give this step a try - Do the four finger swipe up or double press the home button to reveal your multi task bar along the bottom. It will show all the apps that you have opened at one time or another. Long press one of these apps until they start to jiggle and red minus signs will appear above them all. Press all the minus signs, this will close them, not delete them. It's a good idea to do this regularly just to keep them all running smoothly, I do mine every night. Check and see if it is operating now. Let us know if it keeps happening.
TIPS AND TRICKS - for those of us who don't know!
iPad 2 64gb 3G
Is there a way to either edit microsoft publisher files, or transfer them to a iPad-2 program that will allow editing? I have been using publisher on a laptop to create tabloid size certificates, and would like to use the iPad-2... Any suggestions?
