Mute button problem
This is a discussion on Mute button problem within the Forum Rules, Help and Info forums, part of the New Member Introductions - Site Assistance category; I have an iPad original (4.3). I am very new at this, too. Somehow the mute button is checked. I have reset this thing three ...
Mute button problem
I have an iPad original (4.3). I am very new at this, too. Somehow the mute button is checked. I have reset this thing three times. It says to use the 'side switch' but there is no side switch. I can hear movies and music but I can not hear downloaded aps. I have called the 'geek squad' but they can't help. I have gone into 'setting' but that didn't work either. I have also made sure the mute switch is in the correct position. I am ready to toss this and go back to my computer. Do I need to buy a new iPad? I appreciate what ever help is out there. Thanks in advance.
11-27-2011 02:02 PM
When you hold your iPad in portrait, with the round home button at the bottom, you should have two buttons at the top on the right hand side, yes?
It may be worth your while downloading the "iPad User Guide for iOS X" where X is either 4 or 5 depending on your operating system, it's very detailed, easy to use, searchable and best of all, it's free.
Have a look here for info on side switch and other mute controls
iPad: Understanding the side switch
Hope this helps
The world is a dangerous place to live, not because of the people who are evil, but because of the people who don't do anything about it!!
64gb wifi ipad2 iOS 5.01 (Jailbroken using Absinthe) : 120GB iPod Classic : AppleTV2 iOS 4.4.4 (Jailbroken using seas0npass)
Originally Posted by
Gabriel1
Thanks for such a quick response! I pushed the top button and pressed on the bottom button. I can see that it changes wether the pad will allow sound. I went to "settings" and I show that mute has a check by it. I again pressed the buttons you mentioned and the mute will not un-check. When I first purchased the ipad, I downloaded the guide. I first looked there and came to what you mentioned. Still no luck in getting my aps to have sound. I would go to an apple store and have them look at it, but I am disabled and going anywhere is difficult. Is there anything else you can suggest?
garyman
Try double pressing your home button, this will bring up a bar at the bottom of your screen with various apps and controls (it may slide left/right, I honestly can't recall if it did that under iOS 4.x.x) but I seem to recall there was a mute control in there.
When you are done, press the mute button once.
You say you pushed the top button, then pushed the bottom button. At the risk of being cheeky, the side switch is on the SIDE. It is just above the volume up and volume down buttons. It is a physical switch which you slide up and down. It has a very definite movement. It doesn't sound from your description that you are looking at the right thing...
13" MacBook Pro 8GB 2.7GHz i7 500GB | iPad3 4G 64GB 5.1.1 (stock) | iPad2 3G 64GB 5.0.1 (absinthe) | iPad1 3G 64GB 5.1.1 (redsn0w) |
iPhone4S 64GB 5.0.1 (absinthe) | iPhone4 32GB 4.3.3 (jbme 3.0) | iPhone3G 16GB 3.1.3 (jbme 2.0) |
iPod Classic 6G 160GB (stock) | AppleTV 2G 4.4.4 (seas0npass)
If it ain't broke... Jailbreak it!
- You may not post replies
- You may not edit your posts
Forum Rules
By DontUnderstandMyIpad in forum iPad General Discussions
Last Post: 02-05-2011, 01:57 AM
By outbackyak in forum iPad Help
Last Post: 01-16-2011, 01:54 AM
By Benm1020 in forum iPad General Discussions
Last Post: 12-29-2010, 10:51 AM
Last Post: 12-29-2010, 07:51 AM
By donka in forum iPad OS
Last Post: 12-08-2010, 06:05 AM
change mute on ipad 2
ipad 2 mute button
ipad 2 mute button how to
ipad 2 mute button location
ipad 2 mute button not working
ipad 3 mute button not working
ipad 3, side switch issue
iphone 4 mute button not working
iphone 4 mute switch not working
mute button not workin on iphone 4
mute button on ipad 3 not working
mute button stuck on iphone
mute switch ipad 2
mute switch on iphone 4 not working
mute switch problem
new ipad mute button
silent button on iphone 4 not working
where is mute button on ipad 3
where is mute button on ipad3
where is silent ipad
