Forum Help and Questions
This is a discussion on Forum Help and Questions within the Forum Rules, Help and Info forums, part of the New Member Introductions - Site Assistance category; or you can use the tweak "easyfindonpage" using the safari browser...
Page 28 of 32 FirstFirst ... 18 26 27 28 29 30 ... LastLast
Results 271 to 280 of 311
Like Tree2Likes
Thread: Forum Help and Questions
  1. #271
    80087
    5 times
    Jul 2011
    285
    iPad2 3G 64GB
    SHSH 4.3.3
    JB
    Manila, Phil
  3. #272
    iPF Super Guru
    40746
    93 times
    NW Left Coast
    3,504
    Quote Originally Posted by vbriggs View Post
    Is there a way to search for text within a specific thread? I was reading a thread that was 47 pages long the other day, and today went back to find a specific post in that thread but could not find a way to search just that thread for the text I wanted. The overall search didn't find the post I wanted for some reason, so I had to go through the thread page by page and search for the text string on each page. Thanks
    Sure! In each thread's toolbar you'll find "Search Thread". If you enter the word(s) or phrase(s) you're looking for there the search will be limited to the thread you're currently viewing. If you need a more global search simply use the "Advanced Search" at the very top of every page. That will return results for all of the threads and/or posts on the entire forum.
    As 88Raymond points out, the search feature for the iPF App is not quite as detailed. If you can use more words or a phrase that will narrow things down though.
    Hope that helps and enjoy the forum!
  4. #273
    39007
    4 times
    Iowa
    40
    Can't post image??
    Tried attaching image using IPF app, but just get error, says contact support. Tried attaching on regular forum using iPad and it won't allow me to get photo?
  5. #274
    iPF Super Guru
    40746
    93 times
    NW Left Coast
    3,504
    Quote Originally Posted by fishcube View Post
    Thanks for the "heads up". The developers are still tweaking the new site...I'll pass this along for a resolution. Thanks again!
  6. #275
    46067
    Kansas USA
    94
    I have tried numerous searches, but can't seem to come up with an answer to this question:
    How do I stop emails from the forum to my email account? I've checked everywhere (I think) in my profile. "General Settings" has stuff that relates to email, but not the specific issue that I'm having. I seem to be getting an email every time someone adds a post to threads I've previously posted in.
    Thanks for your help!
    -Deb
  7. #276
    37823
    479 times
    Cranbrook, Kent, UK
    15,256
    Quote Originally Posted by debsylvania
    -Deb
    You can unsubscribe in the User CP (control panel) section although from experience you then need to manually unsubscribe to threads which you are subscribed to prior to this. I use the app for this as I can just swipe left to right on the thread in the subscribed tab and it gives you an unsubscribe button.
  8. #277
    iPF Super Guru
    40746
    93 times
    NW Left Coast
    3,504
    Quote Originally Posted by debsylvania View Post
    -Deb
    Hi Deb. What Gabriel said. Here are some more ways to unsubscribe as well...
    Every email you receive has an "Unsubscribe" link in the lower portion of the body of the email.
    When you're visiting a thread on your computer you can unsubscribe by clicking on "Thread Tools" (top of every thread) and then on "Unsubscribe from this thread" in the drop-down menu.
    You can also unsubscribe to multiple or all of the threads that you’ve posted on in the User CP (control panel) section. Click on “Settings” (top of every page to the right of your name) then “Subscriptions” in the left-hand panel, then check the box of the threads that you want to unsubscribe from then at the bottom of the page click on the “Selected Threads” button and then “Delete Subscriptions” from the drop-down menu.
    In the iPF App swipe (single finger) left or right on a thread in the subscribed tab and then on the "Delete" button. Also on the iPF App, while you're in a thread you can also tap on the action box (small box with a right-facing arrow) at the top right-hand side of the thread and tap on "Unsubscribe from Thread" in the drop-down menu.
  9. #278
    37823
    479 times
    Cranbrook, Kent, UK
    15,256
    Quote Originally Posted by richsadams
    Thanks Rich.....I knew that you would be along to save me a lot of tapping!
  10. #279
    46067
    Kansas USA
    94
    Thanks so much, the two of you. That's going to declutter my mailbox by a bunch.
  11. #280
    iPF Super Guru
    40746
    93 times
    NW Left Coast
    3,504
    Glad to be of service!
    I forgot to mention that you can also configure your subscriptions - if you want to be subscribed to threads you've posted in or not. Log into the forum on your computer and click on Settings (top of the forum to the right of your name) > General Settings (left-hand menu). Under "Messaging and Notifications", "Default Thread Subscription Mode" there's a menu button that controls what happens when you post a new thread, or reply to a topic.
    Enjoy!
  1. App Help - iMovie
    By Budbama in forum iPad Help
    Last Post: 08-12-2011, 12:59 PM
  2. Import AVI to iMovie, importing AVI files into iMovie for Mac OS
    By tigerboy in forum International iPad Users
    Last Post: 05-02-2011, 08:47 PM
  3. Editing with iMovie
    By Broseph in forum iPad 2 Forum
    Last Post: 04-23-2011, 12:15 AM
  4. iMovie?
    By Fire Fighter 43 in forum iPad 2 Forum
    Last Post: 03-12-2011, 04:10 PM
gray screen on ipad
gray screen on ipad safari
grey screen on ipad
how to lower grey screen on ipad safari
ipad 2 gray screen
ipad 2 safari gray screen
ipad gray screen safari
ipad speaker icon won't go away
ipad2 gray screen
sound icon won't go away
why does ipad screen go gray
why does my ipad screen go gray
