Forum Help and Questions
This is a discussion on Forum Help and Questions within the Forum Rules, Help and Info forums, part of the New Member Introductions - Site Assistance category; Of course it's a scam, and the people posting these links all over our site (against forum rules) get $34 if you fall for it........
iPad Master!
Bremen Cole
iPad 1st Gen 16G
05-01-2010 08:33 AM
Something I noticed today while trying to post via my iPad.
When I wrote the post, it was pretty long, so the dialog box scrolled down to accommodate the extra text. That's fine. But the problem was when I wanted to review some of what I wrote. I noticed that the scroll bar does not show up on the iPad in the Quick Reply box. So I can't see the earlier text.
The solution, if you can call it that, was to hold down on the screen which brings up the magnifying glass. You then move the magnifying glass up. This... sloooowly.... moved up the screen until I got to the top of my text.
Any chance you can correct for this? Just thought I'd mention it.
Originally Posted by
SteveNYC
You can scroll inside the reply box by using two fingers to pan instead of one. I learned that little trick from Max. Before that, I was using the same method as you
wot_fan
Nice!!! Good tip!
iPad Junkie!
I want to thank you for closing what I thought was an inappropriate topic
iPad Junkie!
Just something I requested in the 3G support thread...
I'd like to formerly request an iPad 3G forum, so that people can discuss 3G problems and issues more openly. This topic has over 2000 replies and over 200 pages, so it is tough to get through. If there was a 3G forum then people could ask and respond to certain questions... it would reduce the redundancy tremendously.
iPad Master!
Is there anyway to remove the "site assistance" part from the title of the "introductions" forum? It seems to confuse new users who often ask general iPad questions there. Have never really seen a "site" question there...... Just a thought
Bremen Cole
iPad 1st Gen 16G
Suggestion
Well since there seems to be no suggestion forum, and I can't start a thread in this forum I guess I'll just add to this message?
Anyway, since presumably many of the users are using an iPad to read the forums, I suggest increasing the size of pagenav. The little arrows/numbers are difficult to hit with a finger.
I'd go at least 150% if not double.
James Goddard
Seconded! I was in this thread to post exactly the same thing. In landscape, switching pages in a thread is barely manageable if you are extremely careful. In portrait mode it is almost impossible.
Just an FYI - when I edit a post (a common occurrence when you're using an iPad to type), the button to resubmit the post says "vote now" :?
- You may not post replies
- You may not edit your posts
Forum Rules
By Budbama in forum iPad Help
Last Post: 08-12-2011, 12:59 PM
By tigerboy in forum International iPad Users
Last Post: 05-02-2011, 08:47 PM
By Broseph in forum iPad 2 Forum
Last Post: 04-23-2011, 12:15 AM
By Fire Fighter 43 in forum iPad 2 Forum
Last Post: 03-12-2011, 04:10 PM
gray safari page on ipad
gray screen on ipad
gray screen on ipad safari
grey popup box on ipad won't go away
ipad 2 gray screen
ipad 2 safari gray screen
ipad 2 safari screen gray
ipad block chitika popup
ipad gray screen
ipad gray screen safari
ipad safari gray screen
ipad sound icon won't go away
ipad2 gray screen
large printable curious george
question 22
safari grey screen
unsubscibe
why does ipad screen go gray
why does my ipad screen go gray
