Edting Posts
This is a discussion on Edting Posts within the Forum Rules, Help and Info forums, part of the New Member Introductions - Site Assistance category; See this page. Why can I not bring up edit according to this I should be able to....
Results 1 to 10 of 12
Like Tree2Likes
Thread: Edting Posts
    302868
    Sep 2013
    Weymouth Dorset England where the Sailing Olympics were held.
    52
    Edting Posts
    Sent from beepsy's iPAD
    13576
    1460 times
    Aug 2010
    Western NY state (USA)
    11,075
    Edting Posts
    Quote Originally Posted by anonbeep View Post
    What happens when you go to your post and hit that blue check mark? Do you get the edit line pop-up as in your picture?
    If no, then could you copy the link to the post you are trying to edit? Because you should be able to edit your own post(s). Maybe there is something wrong with the post...
    1546 times
    Walla Walla, WA
    15,471
    Hold in mind that not all of the forum areas allow editing of posts. I'm a major sinner when it comes to reading my posts for errors after I hit Post, so I'm always running up against this in the News forum threads.
    Mickey330 likes this.
    302868
    Sep 2013
    52
    Quote Originally Posted by Mickey330 View Post
    What happens when you go to your post and hit that blue check mark? Do you get the edit line pop-up as in your picture? If no, then could you copy the link to the post you are trying to edit? Because you should be able to edit your own post(s). Maybe there is something wrong with the post... Marilyn
    Can't see 'my posts' I can see subscribed is that what u mean. Any post I hit the blue check on never shows an 'edit' or none that I can see. I've had a real good look at this, I don't think there's anything wrong with the set up cos everything else works good in IFP. Can't see what I doing wrong tho
    1546 times
    Walla Walla, WA
    15,471
    Hmm.
    Try deleting the app, then re-downloading it from the App Store. Make sure to sign in. I think that is under the Forums tab, or maybe the Profile tab.
    There's is probably some lesser thing you can do to fix it, but hunting that thing down will likely take longer than this drastic, but easy, fix; and it's not like you can lose any data. It is all on the site.
    Since no one has done so yet I'll also include the list of usual fixes below. In case you're not familiar with all of them. You can try them first to see what happens. I don't recommend the last one in your case. More trouble than it's worth in this case. Reset All Settings isn't likely to help with an app that has no setting in the Settings app.
    The Usual Fixes
    Close/Clear the app:
    iOS 6: With the problem app closed, double tap on the Home button to get the multitask bar. Tap and hold on any icon in the bar until they jiggle, then tap the minus sign on the problem app.
    iOS 7: Double tap the Home button to get the multitasking display. Swipe up on the problem app's thumbnail image (not the icon).
    Reset All Settings: Another, somewhat more drastic thing you can do is Reset All Settings. You'll find this under Settings > General > Reset > Reset All Settings. It won't erase any of your content, apps, or accounts; but you will have to go through most of your other settings and re-tweak them back to your liking.
    302868
    Sep 2013
    52
    Hmm. Try deleting the app, then re-downloading it from the App Store. Make sure to sign in. I think that is under the Forums tab, or maybe the Profile tab. There's is probably some lesser thing you can do to fix it, but hunting that thing down will likely take longer than this drastic, but easy, fix; and it's not like you can lose any data. It is all on the site. Since no one has done so yet I'll also include the list of usual fixes below. In case you're not familiar with all of them. You can try them first to see what happens. I don't recommend the last one in your case. More trouble than it's worth in this case. Reset All Settings isn't likely to help with an app that has no setting in the Settings app. ------------------------------ The Usual Fixes ------------------------------ When you have problems with an app it's a good idea to clear it from RAM. Close/Clear the app: iOS 6: With the problem app closed, double tap on the Home button to get the multitask bar. Tap and hold on any icon in the bar until they jiggle, then tap the minus sign on the problem app. iOS 7: Double tap the Home button to get the multitasking display. Swipe up on the problem app's thumbnail image (not the icon). If that does not work try a restart, Restart: Hold down the power button until the power off slider appears. Slide it off. When the iPad finishes shutting down, hold down the power button again until the Apple logo appears. Apple recommends you restart the iPad at least once a month. and then a reset if that does not work. Reset: Hold down the power and home buttons until the Apple logo appears. The iPad will reboot. This usually takes a bit longer than a restart. Reset All Settings: Another, somewhat more drastic thing you can do is Reset All Settings. You'll find this under Settings > General > Reset > Reset All Settings. It won't erase any of your content, apps, or accounts; but you will have to go through most of your other settings and re-tweak them back to your liking.
    Hi Twerppoet. Since I hav had my iPad
    1546 times
    Walla Walla, WA
    15,471
    I'm guessing not everything you meant to say got sent. Or you are answering a question I don't remember asking. That happens too.
    J. A. likes this.
    302868
    Sep 2013
    52
    Hmm. Try deleting the app, then re-downloading it from the App Store. Make sure to sign in. I think that is under the Forums tab, or maybe the Profile tab. There's is probably some lesser thing you can do to fix it, but hunting that thing down will likely take longer than this drastic, but easy, fix; and it's not like you can lose any data. It is all on the site. Since no one has done so yet I'll also include the list of usual fixes below. In case you're not familiar with all of them. You can try them first to see what happens. I don't recommend the last one in your case. More trouble than it's worth in this case. Reset All Settings isn't likely to help with an app that has no setting in the Settings app. ------------------------------ The Usual Fixes ------------------------------ When you have problems with an app it's a good idea to clear it from RAM. Close/Clear the app: iOS 6: With the problem app closed, double tap on the Home button to get the multitask bar. Tap and hold on any icon in the bar until they jiggle, then tap the minus sign on the problem app. iOS 7: Double tap the Home button to get the multitasking display. Swipe up on the problem app's thumbnail image (not the icon). If that does not work try a restart, Restart: Hold down the power button until the power off slider appears. Slide it off. When the iPad finishes shutting down, hold down thework power button again until the Apple logo appears. Apple recommends you restart the iPad at least once a month. and then a reset if that does not work. Reset: Hold down the power and home buttons until the Apple logo appears. The iPad will reboot. This usually takes a bit longer than a restart. Reset All Settings: Another, somewhat more drastic thing you can do is Reset All Settings. You'll find this under Settings > General > Reset > Reset All Settings. It won't erase any of your content, apps, or accounts; but you will have to go through most of your other settings and re-tweak them back to your liking.
    Hi Twerppoet. Since I hav had my iPad, Sept 7th, I hav always turned it off ( shut it down) overnight. I notice now u say do it once a month, as does the help menu which I chekd. Is that too much, wld it cause me a prob? Now I have been thro my post again and now I can see edit!
    Iwas in Asda earlier to use their wifi which wld not work, went services and assured it switched on, now I go to Asda for updates, backup and free wifi. Please see pic. This message came up so I turned off wifi and iPad worked and the sky app updated, now then, another message came up, this iPad is not backed up and will not back up without wifi, in the means time I now have my edit back? Asda wifi always worked b4 but iCloud should do a backup in there and it has not, I go in Asda at least once a week with this now. Beeps
    iPF Expert
    258192
    1736 times
    Nov 2012
    Apetlon, Austria
    8,758
    The advice says "at least once a month". I turn off my iPad every night, when I don't use it. No problems with all of my devices.
    Johanna A.
    You will recognize your own path when you come upon it, because you will suddenly have all the energy and imagination you will ever need. ~ Jerry Gillies
    1546 times
    Walla Walla, WA
    15,471
    The alert in the iPF app is fairly normal. The forum gets bogged down now and then (lots and lots of users) and sometimes it throws out an error or two. Most of the time you can just try again and it works. Worst case, clear the app from RAM as per the 'usual fixes' I posted, and try again.
    Backups to iCloud only happen automatically when three things happen: 1) you have an internet connection, 2) you have the iPad plugged into power, 3) you are not actively using the iPad, and have not been for a while. From the sounds of things you rarely have all three of those things at once. You can still force a manual iCloud backup by going to Settings > iCloud > Storage & Backup, and tapping Back Up Now.
  1. New posts
    By MJervis in forum New Member Introductions - Site Assistance
    Last Post: 05-31-2012, 06:04 PM
  2. Where did the posts go?... Posts missing from Official iPad2 Jailbreak Thread
    By Jenningsville in forum New Member Introductions - Site Assistance
    Last Post: 02-25-2012, 11:40 PM
  3. how to see my posts
    By irispad in forum New Member Introductions - Site Assistance
    Last Post: 06-29-2011, 02:26 PM
  4. New Posts
    By sticky1 in forum New Member Introductions - Site Assistance
    Last Post: 12-05-2010, 07:04 PM
