iPad 3 in Ice Block - Fix Overheating Problem
This is a discussion on iPad 3 in Ice Block - Fix Overheating Problem within the Air Playit (Digiarty) forums, part of the iPadForums.net Sponsors category; Recently, ZooGue (a producer of tablet & mobile phone accessories), has made a freeze test on the new iPad 3. As the videos shows, previously ...
Results 1 to 1 of 1
    162254
    6 times
    Feb 2012
    160
    Recently, ZooGue (a producer of tablet & mobile phone accessories), has made a freeze test on the new iPad 3. As the videos shows, previously the trier puts the iPad 3 into a waterproof bag and keeps the device charging.;then remove the ice block "carefully".
    And the new iPad 3 keeps working well during & after freeze. See the video:
how to fix ipad 3 overheating
ipad 3 overheat fix
ipad 3 overheating fix
ipad 3 overheating fixed
ipad 3 overheating issue fixed
ipad 3 overheating problem
ipad 3 overheating problem fix
ipad 3 overheating problem solved
ipad 3 overheating solution
ipad overheating fix
ipad overheating solution
new ipad overheating fix
